RSview32 Works can't open graphic
When I try to open a graphic when using  RSview32 Works a window pops up and tells me that I don't have security to open graphic. Does anyone know how I can open graphic?
RE: RSview32 Works can't open graphic
Sounds like whoever generated the graphic enabled security on the screen.  You'll need to login with the proper password to be able to open the graphic.
Hope that helps.
