Books about vertical axis windmills
Hi all
I'm looking for some serious book about vertical axis windmills. I need as much technical infos as possible about Savonious, Darrieus, Lenz and other VAWTs.
Can you suggest some good books? I've only found books about HAWT until now.
Please help me!
Bye
Please help me!
Bye
RE: Books about vertical axis windmills
They actually built a couple of fairly large 'H' configuration units.
Had trouble with the torque tubes busting due to the cyclic loading as I recall.
A few good google searches should get you on the right track, I've researched this a couple of times but no books spring to mind.
KENAT, probably the least qualified checker you'll ever meet...
There's only a little wrong thing in your list... all listed books about VAWM are unavailable...
Any other suggestions?
For Kenat
Thanks for the tip, i'm gonna check it out!
Bye
Contact the publishers and authors direct.
