Table of built in Keyboard Shortcuts
Does anybody out there maintain a spreadsheet of some other convenient form of a listing for the keyboard shortcuts?  thread561-188501: full list of "hotkey" combination has a pretty good list but some of them are no longer valid in NX 5.  For example ctrl+w does not take you to the Gateway application, it brings up the Show and Hide menu for part management.
RE: Table of built in Keyboard Shortcuts
While running NX 5, go to Tools -> Customize... and select the button at the bottom of the dialog titled 'Keyboard...'.  When the next dialog comes up, select the button at the bottom right titled 'Report'.  This will list all of the current 'shortcuts', including any that you have added using the customize tools.
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
Beautiful.  Looks like it is missing a few however, like 0 thru 6 for the number of decimal places on your dimension you are placing.
I think you will find that those are technically not 'shortcuts' but rather an example of a functional behavior built into a particular command.  Sort of like the use of the Ctrl key to enable/disable certain 'features' while in some mode or dialog.
John R. Baker, P.E.
NX Design
Cypress, CA
