ASME Section X - Metal Reinforced Vessel?
I am looking at using a metal strap reinforced FRP pipe in a pressure vessel application but need to qualify the vessel to ASME Section X code. Although as an FRP vessel I feel it should fall under the "jurisdiction" of Section X, the pipe has ductile metal (steel) straps imbedded in the FRP that add to the hoop strenght. My concern is whether ASME would "recognize" this as an FRP vessel under the jurisdiction of Section X given it is internally reinforced with steel straps. Note that the steel straps are fully encased within the FRP inner and outer wraps. Any Section X experts out there willing to provide input?
RE: ASME Section X - Metal Reinforced Vessel?
You should probably get the client and the jurisdiction of installation involved. I do not know of an applicable code of construction other than ASME X. In theory you would only be substituting the steel properties for the fibre properties for the applicable volume fraction. This may be beyond the underlying assumptions which were made when the code was developed.
Good Luck.
EJL
