SolidWorks and ProEng
I am new to 3D modeling (with some knowledge of SolidWorks now) and was wondering if ProEng is better or if they are both the same?
I know that this is a SolidWorks forum but a fair point of view will be appreciated :))
RE: SolidWorks and ProEng
Timelord
just wanted to add that you might want to consider what your customers and clients are using. if most of them using Pro/E, then Pro/E might make sense. otherwise, SolidWorks has many advantages as Timelord wrote.
I'm an industrial designer and have really enjoyed the improvements to the surfacing capacity and interface in the last five or so years--getting much closer to being a top surfacer than it was previously. (Yeah, I still have my aggravations with it.)
You may want to check both sides for support costs and qualities, add-on costs (such as software modules), and of course, try out each type of software for their respective trial periods. Be careful of the typical presentations from each side--if you get in-person presentations, see if it can do things that represent what you need (instead of merely whatever the canned presentation can do). Good software for your needs will step outside of the immediate boundaries of the presentation and prove to be flexible.
Jeff Mowry
www.industrialdesignhaus.com
A people who value security over freedom will soon find they have neither.
From what you said, I can see that ProEng is the standard or more used, but SolidWorks is improving and is taking it's proper place now.
My client asks for SolidWorks that's why I used it, but what do you think? Will it be easy to shift to ProEng easily if I will need to, or it will take more time to use it efficiently (after using SolidWorks for sometime)?
Jeff Mowry
Pro/E is a considerably more cryptic and regimented in its interface. More difficult to learn its "language".
However, keep in mind that most of the really interesting surfacing features in ProE don't come with the base package. You'll have to purchase the not so cheap ISDX module (~ $10K). The only SW surfacing feature that is not available in the base package is ScanTo3D (allows conversion of point clouds to 3D surface models).
One last thing. Stay away from Mechanical Desktop. It's basically an AutoCAD add-on. Stay away from all things AutoCAD. If you're going to go Autodesk, try Inventor instead. I prefer both SW and ProE over IV, but it's slowly catching up.
In the end CAD is just a tool. They all use essentially the same basic features. Although the nuances might be different, I've gone back and forth between SolidWorks, ProE, and Inventor without any major headaches. They all have their pros and cons. So bottom line, stick with whichever CAD software your customers request. This will benefit you the most in the long run. Hope this helps.
MDT has not been sold by Autodesk since Feb 1982.
Huh? Where'd you get that gem?
-handleman, CSWP (The new, easy test)
I've been guilty of still feeling like it's the '90s, but '80s???
Flores
Was a MDT user and ATC instructor since way back. Last ATC class I did was back in 2002. In Feb of 2002 Autodesk announced that MDT would be bundled free with Autodesk Inventor Series. I can Google a press release if you have trouble finding the information.
Later free bundled releases might have a What's New of only 1 or 2 items. (usually related to Inventor support). Autodesk didn't even bother to ship MDT with the latest release (2009) with the explanation that few people are even bothering to install it anymore (still ships with AutoCAD Mechanical/AutoCAD for free).
So to repeat, MDT is no longer sold as a product by Autodesk. There has not been a MDT class at AU since 2004 as far as I can determine.
Pro/E runs better (if you like torture) on any of the several machines that I use than SWX. Most of my machines are not particulary good. I would rather use SWX even with the occasional crashes. (I don't have any of the additional modules of Pro/E.)
SWX is much more usable (2007 vs WF2), but Pro is much easier on the processor when you get to complicated models.
If I'm doing something simple, SWX will generally get it done much quicker. If I'm doin gsomething complicated then Pro usually has a better depth of tools to get it done without spending most of my day watching a tiny hourglass.
SWX also has an advantage in that rendering and animation is much cheaper and easier to use than the Pro equivilents.
-b
yes, seems to be a little faster, even on slow hardware; this might have something to do with the more regimented work flow.
ProE really shows its unix roots as i think a lot of old code is still there. it uses massive configuration files to set up the cad environment; which can be good or bad, depending if you like editing configuration file (but also allow to easily change configurations though multiple configuration files). if i remember correctly, does not allow for file name spaces, as the old unix file systems couldn't deal with this.
extremely regimented, which may have been fixed, but i was unable to use workflows that seems pretty natural in other cad systems. seems to have a hierarchical assembly system that i found bizarre and a horrible paper environment.
most of my experience has been with inventor, which i still feel is the most intuitive of the packages i have used, although i am starting to like alot of solidworks. Where i reside solidworks is the defacto standard, which really is an asset when it comes to sharing files. if you have to share alot of files, its not always good to be different.
This feature alone drives me to use ProE on large projects with lots of surfaces.
-b
Copygeom only pulls in the surfaces that you need. It doesn't pull the parent part into session. In an assembly where dozens of parts may reference the master it makes a big difference.
Believe me, I have no love for Pro/E, but this is the one area where SWX just doesn't measure up yet. Unfortunately, with their (and seemingly everyone elses) trend of piling on features rather than speeding up the software, I doubt they ever will. Unfortunately it seems that Moore's law is having trouble keeping up with SWX.
-b
Of course Insert Part replicate some of the functionality, but there's lots of ways to replicate some of the functionality. You could export iges, you could make assembly references, you could painstakingly copy all of the dimesions from your surface model... but none of them are anywhere near equivilent to copygeom for complex multipart assemblies. I'm talkin' 30 min regens on stuff that takes Pro/E (on the same machine) less than 3 min.
Don't imagine killing a bear with a .45. Imagine killing an elephant with a .22 pistol. Possible, but it's going to take you many times longer than with the appropriate tool. I gots me 2 hammers: SWX and ProE. For jobs that call for big assemblies of surface intesive parts, I pick ProE. For just about everything else I'll choose SWX.
InsertPart01
InsertPart01
See attached
Anna Wood
SW2008 SP4.0, Windows Vista SP1
IBM ThinkPad T61p, T7800, FX570M, 4 gigs of RAM
http://designsmarter.typepad.com/solidmuse
http://www.phxswug.com
-b
Good mention of Insert Part which is the tool for any Pro/E users to use to allow functionality similar to Copy-Geom. It allows importing Absorbed unabsorbed sketches Surfaces Solid Planes and all else. you can then insert Delete Body or Delete surface commands to show only the geometry you need to reference. You can also create Configurations with each of the entities or features needed by the referencing part to replicate what the copy geom would do.
Not to mention anything more than the following. SolidWorks Sketch tool is Far Far superior to Pro/E's one. Pro/E forces ellipses to Horizontal and Vertical Major/Minor axes. Sketched Splines can provide Curvature continuous transitions and You can add dimensions to splines in 3D sketches which is a lot better than having to drag points to the location you want. Mentioning the 80s Pro/E is still stuck there.
If you want file names to max out at 31 characters and not allow spaces in names and like being alerted about minor problems in the model and constantly fixing mistakes, SolidWorks lets you do things right the first time. SolidWorks lets you design as you go whereas in Pro/E you have to think things completely through before starting if you'd like to finish ontime.
I started on Pro/E and used to do QA work for the company so it doesn't faze me much but everyone should at least try the different programs out to see what suits there needs. However SolidWorks provides more Bang/Buck functionality wise and is constantly adding new Functionality where Pro/E is trying to fix or create new barely usable functionality.
SolidWorks can import Pro/E parts and recognize features where as getting Pro/E Wildfire 4 to recognize SolidWorks parts gives some you imported this wrong message. Wildfire 3 contains no real improvements over WF2 except maybe fixing a few bugs and better than crappy sketch performance.
SolidWorks Patterns are also more flexible than WF patterns because you can suppress them without suppressing their originating feature.
Michael
You can spend all day picking apart individual software features. I could create long lists for both ProE and SWX. Most of them are just preferences that don't keep me from getting my job done.
I spend some of my time working with large surface intensive models. I am quite versant in both Pro/E and SWX as I don't always get to choose due to customer needs. I find SWX superior for "fast and sloppy" work. It has all sorts of great surfacing tools that create good looking, but poor performing surfaces (poor offsettability and extendability). For anything more than 6 parts referencing the same master model, it's Pro/E hands down. The faster regen times make up for any ease of use advantage that SWX might have.
-b
