Reading the USB port
I need to write an application that can access data comming in on a USB port. Does anyone know how to access a device on the USB port or can anyone point me in the right direction to find out how to do this?
Cameron
RE: Reading the USB port
CCRum,
What operating system are you using?  And what programming language are you using?  If you are writing in C, C++ or Java, you can open a stream to the USB port just by giving the port's name to the open statement.
  -Kevin
