John, using your grip
John, I've been looking at previous attribute posts, and in one, you posted a grip of yours which is called "dwg_info" , I've tried chopping it up but i don't understand the language.
All i want is a grip, which adds the current date to the existing "date" attribute (overwrites).
But the date needs to be day/month/year, format, using a dot between each.
Could you please help ?
RE: John, using your grip
'assign_date-1.grx' assigns a Part Attribute titled DATE in the format of 'dd.mm.yy'.
'assign_date-2.grx' assigns a Part Attribute titled DATE in the format of 'dd.mm.yyyy'.
I hope this helps.
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
the first one is the one, I've been trying to string it together 3 times, to get it to add, DRAFTER_DATE , ENGINEER_DATE , APPROVED_DATE .
I thought i'd be able to sus it from reading the other programs. I've looked at help, but i think i need a training course. Would you mind altering it to add these, Thanks....
John R. Baker, P.E.
NX Design
Cypress, CA
I'll see if i can understand a bit more how to write them.
Are there any tutorials or training available ?
John R. Baker, P.E.
NX Design
Cypress, CA
Incidentally, in one of the posts, you advised someone to do this type of thing with a grip, cos journal doesn't do it as well, and since, it sounds as if grip will be dropped, will journal be enhanced to encompass this functionality?
John R. Baker, P.E.
NX Design
Cypress, CA
would you be interested in a .vb Journal file that does that? I can post one, although I think I got it off of this forum, so perhaps the author could post it (someone named Henry?)
-Derek
DL Engineering Services
specializing in CAD Design Consultation Services
-Derek
