looking for info on coatings
Looking to coat a brown stock storage tank. If anyone has any info please let me know.
The vapor space gas is the zone we are most concerned about, there is severe corrosion.
Components measured were dimethyl sulhide and dimethyl disulphide.
Humidity 100%
The liquid components of the tank run at about 70-80 degrees celsius
With a pH of around 11
Humidity 100%
RE: looking for info on coatings
<<A good friend will bail you out of jail, but a true friend
will be sitting beside you saying " Damn that was fun!" - Unknown>>
Hi.
Both epoxy- and phenolic-based coatings may be the best place to start.
Here's a suggested manufacturer:
http://www.heresite.com
Ask about permeation strength (% coating weight gain) while exposed to your compounds and temperature.
Keep in mind, too, these products are electrically insulating. So, given the flammability of methyl sulfide, be sure everything is well grounded.
For more helpful information on corrosion protective coatings, see:
<a href="http://w
Good luck!
William Gunnar
http://www.IndustrialCoatingsWorld.com
