1977 NDS value
1977 NDS value
1977 NDS value
Does anyone have a 1977 NDS handy where they can tell me the design values for southern pine (E, Fb, and Fv)?
RE: 1977 NDS value
FSS .. do you mind telling me why you need such info?  Wouldnt it be more conservative to just use latest nds value?
Never, but never question engineer's judgement
RE: 1977 NDS value
NO.  Older trees have different values.  The difference between first and second growth, let alone third, is a lot.
If you check the 1977 UBC, Table 25-A-1, you will find your values.  As they are member size and type dependent, it is too variable to post here.  I will try to scan the table for you and post later.
Mike McCann
MMC Engineering
RE: 1977 NDS value
Then if you are confident about it.. why not just look it up as select structural from latest nds value?
RE: 1977 NDS value
Thanks for the info Mike.  I am trying to verify/recreate load tables taken from an old design guide handed to me.  I don't trust anything till I check the numbers myself!
RE: 1977 NDS value
Contact the Southern Forest Products Association for design values.  I will check to see if I have a older SFPA grading book.
You could also look in an earlier edition of the AITC TCM.
The difference in design values has more to do with changes in grade rules and the manner in which values are assigned then on whether or not the wood was first growth.
The is a difference in the fact in first growth you would get more material that would grade as dense grain.  The design values are higher for dense selected structural than for select structural.
RE: 1977 NDS value
"If you would like to purchase archival copies (photocopies) of pre-2001 editions of the NDS, contact the AWC Helpdesk at 202-463-4713. Cost is $25 per copy and includes shipping and handling. Use a credit card to order over the phone or fax your request to 202-463-2791. A check or money order made out to the American Forest & Paper Association can also be mailed to:
1111 Nineteenth St., NW, #800, Washington, DC 20036,
Attn: American Wood Council."
