Assembly Cuts, HELP
Assembly Cuts, HELP
I have the assignment to figure out how to put over 10000 assembly cuts into a large assembly. 1st assembly gets about 300 cuts or holes, we have not decided which will be better. That assembly is assembled to the next level and it will get 500 more cuts or holes and so on. When I am thru there will be over 20 assembly levels stacked up with all these cuts or holes. This will also have a lot of nested cuts. We do have 64 bit machines but I think that will even give them problems when I am finished.
Has anyone ever solved this before?? HELP
RE: Assembly Cuts, HELP
If you do get the assembly cut to work you probably should look into copying the surfaces of the first cut, patterning the surfaces and solidifying. This can speed regeneration time a lot.
I wish I could do this another way but they want Engineering to match Manufacturing. So I need to try to comeup with something or request a bigger computor. LOL That's an IDEA
