Attribute order.
Attribute order.
I.m trying to put together some drawing sheet templates. I'd like to get the attributes in a particular order but when I save and then open the template and edit, the attributes are not in the order that I wanted. I was under the the impression that I have have to go in reverse order but this doesn't to be the case. Can anybody help.
RE: Attribute order.
Referring to the AutoCad 2002 Users manual:
If the window or crossing selection is used to select the attributes, the order of the prompts is the reverse of the order in which you created them. Make sure the object sort method on the User Preferences tab in the options dialog box (Options) is set for object selection if you plan to use crossing or window selection.
Try avoiding the selection of the attributes using window. You should be able to control the prompt order by picking the attributes individually in the order you want them diplayed.
Hope this does the trick
Regards Adrian
Then still in picking, as advised above by Adrian.
You can use the REFEDIT command.
Farzad
You can use the command "BATTMAN" in the AutoCAD 2002.
Farzad
