UG SKETCH QUESTION
UG SKETCH QUESTION
I developed a spline in Sketch and then Swept a profile along that spline. While in Sketch I am using ANIMATE dimenssion, can I see a live update of 3D Swept and record it so I can show it in an external UG enviroment ?
RE: UG SKETCH QUESTION
If so one easy way to do so is to use third party screen capture software. If you have actually created some solid models from your data than you may be able to capture that using animations from within NX.
Best Regards
Hudson
