Welding guideline for SA 335 p22
I am wondering if there is a guideline available for fabrication and welding of SA 335 P22 carbon steel
RE: Welding guideline for SA 335 p22
Guideline for fabrication is based on the application for this material - for example boiler/pressure vessels ASME B&PV Code. This code gives rules for fabrication and welding. For piping, go to the ASME Power Piping Codes.
AWS Welding Handbook Vol 4, 8th Edition
You may also get better replies if you post in the Welding Bonding & Fastener Engineering Forum particularly as the material of interest is not a stainless steel!
Steve Jones
http://www.pdo.co.om/pdoweb/
thanks guys
