Modeling A Twist Drill
Does anyone have any experience modeling a twist drill in SolidWorks? I have successfully made the shaft and cut flutes along it, but I'm having trouble with the chisel edge and the lip clearance angle. Right now I have a square ended cylinder with flutes cut down the side. I've tried making revolved cuts, but there is always an issue with the interface between the two "halves" of the point.
-Thanks
RE: Modeling A Twist Drill
You would have to add additional Planes to perform the cuts, depending of course on the type of facets you wanted.
http://www.mmsonline.com/articles/068901.html
I can't see why you would need this level of detail for a twist drill model, including the helix-based flutes.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the be
Nice link, MM!
-handleman, CSWP (The new, easy test)
Thanks for both links MadMango, and rollupswx! I just got it worked out.
