P-delta ~ secondary
P-delta ~ secondary
What are other secondary analysis besides P-delta
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: P-delta ~ secondary
There are two types of second order effects:
P-smalldelta - which is from the deflection of the members between its ends (e.g the buckling of a column under bending)
P-large delta - is the translation of the end points in relation to each other e.g. like the columns of a portal frame under sway conditions.
Hope this helps.
csd72 is absolutely right.
