welding machine to weld 0.2 to 0.5mm thick sheets in SS316
hi everybody
can anyone help me to select the welding m/c to weld metallic plate of 0.2 to 0.5mm thick ss316 plates radially
I know it is done through TIG welding m/c, but I m searching for actual configuration.
plz help
thanks
plz help
thanks
siddik
RE: welding machine to weld 0.2 to 0.5mm thick sheets in SS316
A good setup and working environment is essential in getting good micro welds. What little freehand work we accomplished an elbow support and stereo microscope were the essential aids.
I would check and see if either company has a video.
http://www.pro-fusiononline.com/
http://www.weldlogic.com/
siddik
