Mathcad syntax
Mathcad syntax
Mathcad syntax
Why does MathCAD recognize .2.12 as 12?  I accidently defined a variable as .2.12 and MathCAD didn't recognize that it was a typo.  Instead of defining the variable as the desired 2.12 it used 12 and it took me a few hours to find the mistake.  After i realized this i was playing around with it and found that whenever you type a period then a number then another period and number mathcad evaluates it as the second number.  Any ideas?
RE: Mathcad syntax
It happenes in V14 M020.
any number of decimal points are allowable within the 'bug', so x:=....12 will give x=12 as will x:=.2.12 or x:= .1.2.012
Definately some sort of parsing bug probably because you can have a literal subscript (used a dot) in a variable and the same dot in a number.
It's still a bug.
Philip
RE: Mathcad syntax
V13 also does this.
RE: Mathcad syntax
I wouldn't expect it to be an XML thing specifically, but V12 was 'a bit of a dog'. They re-wrote much of the internal engine! I'm suprised it hasn't been spotted & reported before.
RE: Mathcad syntax
I'm using version 14
RE: Mathcad syntax
It's not an XML issue, per se, but starting with v12, the revamping was also driven by the desire to use XML file format instead of the binary format.  This most likely resulted in changes to the parsing routines.
TTFN
