Motor turn down - what does it mean?
In a new position at work, and guys around me are talking about motor "turn down".
Would someone please give me a description of what "turn down" means.
Mark
Mark
RE: Motor turn down - what does it mean?
Therefore a higher turndown ratio implies slower speeds are possible without causing damage. i.e. the speed can be "turned-down" more.
Our motors have a range of 50-105% RPM. At 50%, the centrifugal compressors are spinning but at normal operating pressures they're performing very little compressing.
old field guy
Example; a gas burner will operate over a range of 250,000 BTU/Hr. to 10,000,000 BTU/Hr. The turn down ratio is 10,000,000/250,000 = 40 or 40:1
Does this explanation fit your context?
Bill
"Why not the best?"
Jimmy Carter
