Is a roof system considered a "diaphragm" for seismic design purposes?
I am trying to calculate the seismic forces that need to be resisted by a roof system. By roof system, I mean the trusses, bearing connections, blocking and decking. Can I consider this system to be a diaphragm? (Covered in section 12.10.1 of ASCE 7-05) The roof system is not part of the main seismic resisting system, but it is a structural component of the building.
RE: Is a roof system considered a "diaphragm" for seismic design purposes?
Mike McCann
MMC Engineering
The "roof diaphragm" is the plywood membrane over the roof truss system, not the roof trusses themselves. Now the trusses have to be able to withstand wind and seismically induced loads applied in certain ways, but the structural diaphragm is the plywood. The roof trusses and intermediate eddge blocking serve to provide support to the diaphragm to stiffen it as necessary, but they are really not a part of the structural diaphragm per se.
Am I missing your question here?
Mike McCann
MMC Engineering
