Can visualization preferences be saved/restored? (NX5)
Sometimes when I load a part created by others, I find the visualization preference settings (background, dimension, sketch colors, etc) are not to my liking. Is there a way to save my preferred settings and apply them in one shot?
RE: Can visualization preferences be saved/restored? (NX5)
Now open and/or edit some part file so that it has all of the visualization options set the way you want them to be and which you wish to pass along to another part file. Now open the new Resource Bar palette and over the 'white space' press MB3 and select New Entry -> Visualization Template. Now when the dialog comes up you can give it an appropriate name and you can also toggle OFF any of the setting areas that you DON'T want the template to modify. Once you've got everything as you want it, just hit OK.
Now open the part file that you wish to modify and go to this palette and drag the template over to the graphics window. Once it has been updated, you will need to re-save your part file, but at this point you should be good to go.
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
I've created one of these as well, I've moved it to somewhere else, and edited the .pax, so it shows a bitmap of my own, as the pallet image, and the same .bmp is used for the visualisation button.
But, even though both bitmaps display properly, when i use the palette, a message reads, "failed to open bitmap file: pref_visualisation " i suppress the message, but next time i open a session, it comes up again, how can i fix this ?
John R. Baker, P.E.
NX Design
Cypress, CA
The palette works and looks fine, but i still get the message, first time i use it.
John R. Baker, P.E.
NX Design
Cypress, CA
if i open the palette, then right click on the button, and edit, i get the visualisation template generator, up, then i OK without doing anything, and i get the message again.
I've even done the whole thing from scratch, without moving or changing anything, and it does it on that one too ??
I believe that's a bug in NX5.
It's fixed for NX6.
Specialty Engineered Automation (SEA)
http://www.sea4ug.com
a UGS Foundation Partner
