Fire case - Relieving temperature
Could you please confirm that the below formula for calculating relieving temperature is always correct for fire case: T1=T0*(P0/P1)with T in K?
eg:
T0=92°C
P0=1.79 bara
P1=5.41 bara
Then, T1=278°C
I ask this because we receive from subcontractor a value of 155°C for this example...
eg:
T0=92°C
P0=1.79 bara
P1=5.41 bara
Then, T1=278°C
"We don't believe things because they are true, things are true because we believe them."
"Small people talk about others, average people talk about things, smart people talk about ideas and legends never talk."
RE: Fire case - Relieving temperature
P0,T0: normal operating conditions
P1, T1: Relieving conditions
P1*V=nRT1
and
P0*V=nRT0
P1/P0=T1/T0
P1*T0/P0=T1
So the validity of said formula will depend on you P/T and gas.
At the stated pressure/temperature its propably not too far off.
Best regards Morten
If the vessel is filled with water then the temperature will increase to the boiling point at the RP+21% (assuming API sizing). If this pressure is 5.41 bara then my steam table says 148 deg C - but thats close enough
Best regards
Morten
When we are dealing with fire contingency, first thing is to establish the scenario & condition of the fluid in vessel :
i) completely fill with liquid ==> Hydraulic expansion
The temperature would be properly close to initial temperature
ii) partially fill with liquid ==> Boiling liquid
The temperature would be at the boiling temperature
iii) completely fill with vapor, gas or supercritical fluid ==> gas expansion
The temperature would be very high. The temperature rise would follow the path between isothermal and adiabatic. Nevertheless, API has considered isothermal...
You may see that the fluid temperature for each case would varies significantly.
After scenario is properly defined, then only think of the way to estimate the temperature.
I have mixed gas expansion in vessel and valve. My apologize.
The last statement
"The temperature would be very high. The temperature rise would follow the path between isothermal and adiabatic. Nevertheless, API has considered isothermal..."
should be reworded as
" The temperature would be very high. The temperature rise would follow the isochoric process (isovolumetric). "
JoeWong
Chemical & Process Technology
JoeWong
Do we still calculate the latent heat in the case of full liquid discharging at initial temp (in above mentionned case i)? If yes i assume at the relieving pressure.Correct?
Generally either wetted surface (liquid present) or unwetted (gas filled).
Usually wetted relief temp will be vapor pressure at Prel. When tank is very full (say over 80-90%) you need to consider two phase flow. You could rigorously evaluate the time-dependency of the type and amount of relief, which I have found to be quite consuming. I now spend quite a bit of time confirming whether I can base my design on vapor flow only before going the rigorous route. Yes, if any liquid is in the tank you will be using the Hvap in your calcs. There is another thread today you may want to read.
Unwetted, you are using ideal gas law to estimate the temperature (Tr = Tn x Pr/Pn). API 521 does a good job of explaining how to evaluate the unwetted case.
