BOM item numbers
BOM item numbers
As always, nothing good is coming out of using the Solidworks BOM for me.
I am trying to change the item numbers on the BOM on one of the parts on a big assembly. When I double click the item number, nothing happens. It thinks for a second like its going to bring up the "are you sure you want to change this number" box, but nothing comes up. Ones that I have changed before will still change, but others wont.
Any solutions? Ive tried restarting and different formatting things...nothing yet.
thanks in advance
thanks in advance
RE: BOM item numbers
If you're using 2008, just grab the row and move it to the position you want. The number(s) will update accordingly.
Jeff Mirisola, CSWP, Certified DriveWorks AE
http://designsmarter.typepad.com/jeffs_blog
Dell M90, Core2 Duo, 4GB RAM, Nvidia 3500M
Bradley
SolidWorks Pro 2008 x64, SP4.0EV2
PDMWorks Workgroup, SolidWorks BOM,
Dell XPS Intel(R) Pentium(R) D CPU
3.00 GHz, 5 GB RAM, Virtual memory 10240 MB,
nVidia Quadro FX 3400
"If it ain't broke, you just haven't looked hard enough." Fix it anyway.
