Dimensions appear after drawing update
Hi there,
I have a drawing that is not up to date (parent CATPart was moved). I re-route the link (via menu commands Edit - Links - Find/Replace...) to the right CATPart, and the link is accepted. As soon as I update the drawing, a whole bunch of green-colored dimensions appear all over in my views... Does anybody know what are these and how to get rid of them?!
Some screen-shots: here's the drawing before update...
[IMG]http://i286.photobucket.com/albums/ll88/slcad/before_update.jpg[/IMG]
... and after
[IMG]http://i286.photobucket.com/albums/ll88/slcad/after_update.jpg[/IMG]
This is a fairly simple drawing, but imagine the pain to erase all of them in a complex drawing... and they are not shown as being green, so I can quickly perform a search...
This might be a matter of settings, I don't know...
Thanks in advance!
Catia 5.16 SP8 BN16
Best regards,
Stely
RE: Dimensions appear after drawing update
The green dimensions are auto-generated. Check under Tools > Options > Mechanical Design > Drafting > the "Generation" tab. The top box is Generate dimensions when updating the sheet. Probably switching this off will fix your problem.
This may be a new behavior due to using a different environment, or maybe someone else used the auto-dimensions and then hid them on the original drawing?
Cheers,
Mark
Those are dimensions generated from 3D constrains...(see Tools-Options-Drafting-Analysis Display Mode).
Uncheck option Generate Dimensions When Update Drawing from Generation Tab in Tools-Option-Drafting.
Fernando
Thank you!
Your suggestion worked perfectly!
Best regards,
Stely
Thanks Ferdo... star for you
Eric N.
hmm MarkAF was first on the line...
Eric N.
smile ,I also noticed that after posting, I experienced some little problems with my net connection at that time.
Anyway, its good when somebody can offer a solution.
Fernando
