Composite Deck Capacity
How to calculate the cross-sectional moment capacity of a composite metal deck with concete and wire mesh?
I have a renovation project which needs to evaluate the existing composite deck with new mechanical units hanging underneath the deck.
After comparing with some catalogs, it has been identified as Vulcraft 2VLI19 or similar. It is a corrugated mental deck with concrete slab. The total slab depth is 5-1/4" with Light weight concrete. The span is 8'-0". The existing wire mesh size is 6"X6" #10/#10.
I can get the uniform load from Vulcraft (260 PSF). However, the mechanical units are using rods to hang from the bottom of the deck as concentrated loads.
What is the proper way to calculate the capacity of the deck for resisting 60 PSF live load plus these concentrated mechanical unit loads?
I am thinking to calculate the cross-sentional moment capacity the same way as culculating concrete beams and slabs. However, the corrugated metal deck stops my thought. It may be too complicate to do so.
What do you think? Please help.
Thank you for your input.
RE: Composite Deck Capacity
e.g. Your phiMn is 260*1.6*(8^2)/8 = 3328 lb-ft
Your LL Mu is 60*1.6*(8^2)/8 = 768 lb-ft
Your availble DL moment is now 3328-768 = 2560 lb-ft
This will be your available factored (at 1.2 though, not 1.6) DL moment.
You didn't say where they are located, so I can't help any further, but that is the approach I would take.
Do the math to convert each concentrated load into an equivalent UDL.
Then sum everything - dead loads, live loads, and equivalent live loads. Don't use the 260 PSF from the catalog as the acceptance critera for the following reason:
If the total is less than 200 PSF (as recommended by Nucor), you are done. The 200 PSF (comes form Note 2 at the bottom of page 47 on the Vulcraft Catalog, see this link:
htt
www.SlideRuleEra.net![[idea] idea](https://www.tipmaster.com/images/idea.gif)
www.VacuumTubeEra.net
1. calculate Mmax for the mechanical unit alone.
2. convert Mmax to an uniform load that would causing the same mangnitude of moment at the location Mmax occurs.
3. check the resulting and actual uniform loads against the known capacity.
4. make sure the slab will not crash by the concentrated load at the hangers (punching shear).
In the OP's situation - a LL of 60psf means the additional load would be 200 psf (260 - 60), but if you apply the proper load factors and you need to know the allowable DL if you only have 60 psf LL, you will get 267 instead of 200 (This comes from 200*1.6/1.2).
Like I said, this can be very helpful.
Now, I have a better idea what to do.
Thank you guys. You are very helpful.
If they tack weld or something just to the deck, the load could possibly peel off the deck bond to the concrete above at the localized hanger points and the composite action between deck and slab might be altered.
Also, the points above are OK - but keep in mind that the primary failure mode for composite deck slabs is loss of shear bond, not flexural failure.
Focusing exclusively on moment is incorrect. You also should look at the shear envelope across the span. Point loads alter this much more than the moment envelope.
Welding of course can be a problem in an existing ceiling space. Thru bolting with a bolt between joist bottom chord could work.Or try cold formed steel studs and TEK/5 screws.
I agree with total PSF methodology when checking bending. Shear probably won't be a problem. Just check the the concrete only slab thickness for punching shear and shear failure modes. Keep redundancy in mind if the load is heavy.
