Tyre clearance
Tyre clearance
Tyre clearance
Can anyone tell me what minimum clearance I could get away with between the sides of a road trailer tyre and a frame. I have always worked with 25mm.
RE: Tyre clearance
Sufficient so the tyre doesn't rub ponder
I would guess that 25mm would be a reasonable minimum allowing for a bit of sway etc in the suspension.
RE: Tyre clearance
It depends a lot on the suspension. With a tight suspension with little toe change and good lateral location, 1" should be OK.
With dual axles, load sharing loose bushes and long travel, 50mm might be required.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
RE: Tyre clearance
I have a bog standard (=bone stock for our colonial cousins) B5 Audi S4 and I can't get a small finger between the tyre and the suspension upright so clearance is about 10mm
RE: Tyre clearance
Most trailers have primitive suspension with poor axle location. I suspect your Audi has a somewhat better suspension with accurate axle location.
RE: Tyre clearance
That's probably 3mm tolerances and 7mm tire growth.
The tire to frame clearance also needs to include lateral compliance of the suspension and a much bigger tolerance stack, 25 sounds good to me.
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
RE: Tyre clearance
Thanks Guys
