Creating or editting properties with a macro
I have a written a macro to populate the properties table for new parts, I also want to use it to update the table for older parts that weren't created with the correct template.
I'm new to macros and vb so I need something simple. Using some borrowed code from this site I've manage to get something working:
Success = swModel.AddCustomInfo3("", "Finish", swCustomInfoText, "")
swModel.CustomInfo2("", "Finish") = "Natural"
This will populate the property 'finish' with the value 'natural' (our default) but if the property has already been set to something else then it overwrites it.  I don't want that to happen I want it to keep the current value.
RE: Creating or editting properties with a macro
I've just reread that and it might not be that clear.  I need it to:
1. if the property doesn't exist, create it and populate it with a set value
2. if the property exists then keep the current the value
Quote (SW API Help):
Description
This property gets and sets the file custom information for the SolidWorks document.
Syntax (OLE Automation)
value = ModelDoc2.CustomInfo2 (configuration, fieldName) (VB Get property)
ModelDoc2. CustomInfo2(configuration, fieldName) = value (VB Set property)
value = ModelDoc2.GetCustomInfo2(configuration, fieldName) (C++ Get property)
ModelDoc2.SetCustomInfo2(configuration, fieldName, value) (C++ Set property)
Input:
 (BSTR) configuration
 Name of the configuration (see Remarks)
Input:
 (BSTR) fieldName
 Name of field
Property:
 (BSTR) value
 Text in the field
If value in the "get" property exist and <> "" then do not change it else delete it and add it with the new value.
This method is obsolete and has been superseded by ModelDocExtension::CustomPropertyManager.
Thing get a little bit more complicated with CustomPropertyManager.
Get rid of your second line.  The AddCustomInfo3 function will not overwrite an existing property.  You can verify this by checking the value of the variable "Success" with a message box.  All you need to do to get your desired behavior is put "Natural" in your AddCustomInfo3 line and get rid of the next line.  So you'll have:
CODE
Success = swModel.AddCustomInfo3("", "Finish", swCustomInfoText, "Natural")
-handleman, CSWP (The new, easy test)
Thanks Handleman, that's got it
