Elliptical Manway
Elliptical Manway
Please let me know how to do code calculations for an elliptical manway which is to be fitted to the shell
RE: Elliptical Manway
Typically, manways are "pressure rated components" i.e. qualified by test.
When an ASME vessel is fabicated, the vendor is responsible to perform calculations on the heads, shell, nozzles etc, However, pressure rated components, such as manways are purchased with a special ASME stamp that verified that it is acceptable for service.
Hope that this helps
MJC
dont we need to do calculations for the rf pad and the opening.
Reinforcement area A=d x tr x F for any direction where
d = opening size in the direction
tr = required thickness of shell,head,..
F = factor for steress diference by directions
Use 1 if you are not sure. See UG-37 for details.
Above formula need to be modified if material's allowable stress are different between shell, nozzle, repad.
