Toggle broken-view macro
Very often I will go to a page that has a broken view and the view is not broken.  By that I mean the view still has the broken-view lines, but there is no clear gap between the lines.
See pic: http://paul-flores.com/solidworks_screenshots/broken_view.jpg
I have to right-click the view, pick "un-break view", then break the again.
I thought instead of doing this several times a day, a broken-view toggle would be the better way to do this.
Preconditions: view is pre-selected
1. Un-break view
2. Break view
CODE
' macro recorded on 06/18/08
Dim swApp As Object
Dim Part As Object
Dim SelMgr As Object
Dim boolstatus As Boolean
Dim longstatus As Long, longwarnings As Long
Dim Feature As Object
Sub main()
Set swApp = Application.SldWorks
Set Part = swApp.ActiveDoc
Set SelMgr = Part.SelectionManager
boolstatus = Part.Extension.SelectByID2("", "FACE", 0.1035512874926, 0.06293938349189, -1999.382179705, False, 0, Nothing, 0)
Part.UnBreakView
Part.ClearSelection2 True
boolstatus = Part.Extension.SelectByID2("", "FACE", 0.09800694802044, 0.06776054825029, -1999.382179705, False, 0, Nothing, 0)
Part.BreakView
End Sub
The problem is that it only works with the original view.   It doesn't work with different views on different pages.
Can anybody help correct this problem?
Flores
RE: Toggle broken-view macro
You might want to check and see if Break and Un-Break are always the same shortcut letter in the right-click menu.  For example, I almost wrote something to make a shortcut for Select Other, but then I realized that it's always the S key in the right-click menu.  So (since I always roll with left hand on keyboard), I can always access Select Other almost as instantly as a single click.  I often don't even see the right-click menu open.
That being said, in this case your macro recorder has recorded the location of your selections.  That's why it only works on the first view.  If you'll get rid of all the code dealing with selections, the macro will work on whatever view you have pre-selected.
CODE
Dim swDwg As SldWorks.DrawingDoc
Sub main()
    Set swDwg = Application.SldWorks.ActiveDoc
    swDwg.UnBreakView
    swDwg.BreakView
End Sub
-handleman, CSWP (The new, easy test)
Thank you much Handleman, you've been a big help as always.   This "broken-view becoming un-broken" has been around a long time, but now that you helped me with a toggle, it looks like they fixed it.
Because of the non-disclosure agreement I don't think I can post the text of the SPR fixes, but I think my problem may have been fixed with SPR# 391246 in SP4.0
Flores
