suction pressure losses in submersible pump?
Dumb q. for the assembled cognoscenti:
I'm working through the hydraulic modelling for my first wet well. Despite a reasonable amount of experience with pumping systems I haven't really worked with sub pumps before. Simple question on its face:
Are there any suction friction losses to calculate with a submersible pump? In a conventional application I would look at, e.g., tank exit loss plus suction piping run loss plus maybe an elbow or two and an isolation valve. In the case of a sub pump the suction is flooded and right there in the fluid, no plumbing in the way. Do I simply assume the suction side friction loss is zero?
thanks
leaky
thanks
leaky
RE: suction pressure losses in submersible pump?
http://virtualpipeline.spaces.msn.com
"What gets us into trouble is not what we don't know, its what we know for sure" - Mark Twain
BigInch, your point is a good one, but I believe I've managed to account for it already. The application is clean(-ish) ambient temperature water so the effects on NPSHa are minimal, and the sump is designed such that the pump suction is flooded well beyond the vendor's recommendations.
I guess what I am saying is that it will be pretty negligible compared to your other losses.
Beware of minimum submergence also.
http://www.franklin-electric.com/Manual/AIM_07.htm
Likewise the close coupled submersibles power ratings include both pump and motor inefficiencies - this is the reason some units look to be inefficient in terms of power input to hydraulic output.
The only time to worry about the submergence is when you are in a tight well, then you may need to be concerned about the flow up past the motor. I am thinking about pumps with very high head as they need all of the NPSH that they can get.
Plymouth Tube
The statement about tight wells is inaccurate. I have seen pumps create a vortex in large ponds.
