Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...The level of expertise is awesome. The nature in which people respond is professional helpful and not the least condescending. I can't say that for most forums..."
Geography
Design of multiple pieces of plywood laminated togetherHelpful Member!
GoCyclones (Structural)
18 Jun 08 15:29
I am in the early stages of trying to develop a design for a small building frame made of multiple pieces of plywood laminated together vertically (probably glued and screwed).  See attached general sketch.  Does anyone have any good references regarding this?
Helpful Member!  MiketheEngineer (Structural)
18 Jun 08 17:11
Any dimensions....
Go to apawood.org or com for help.
With this kind of configuration - actaul testing may be required...
COEngineeer (Structural)
18 Jun 08 23:36
Do you have to make it structural?  Usually you can use pointy edges and finish it off with plywood to mayke it curvy.  I am not sure what you are trying to do but your sketch is very skinny.  What are you trying to do?
Never, but never question engineer's judgement
19 Jun 08 9:20
The first building is 12' wide by about 8.5' tall at the center.  If this one works, they will of course want a larger one.  If it is not clear, the sketch is only of a single frame.  Each frame would be connected by lateral bracing as needed.  They want the curved look and would like to make it solely out of plywood to keep cost down, if it is feasible.  The sketch is just a quick one to show the general idea.  The depth of the frame and how many pieces of plywood are required for each frame is what I need to determine.
civilperson (Structural)
19 Jun 08 17:54
Easily solved once you know the loads to be imposed.  Snow, wind, seismic, 20 psf live load, and self weight of deck need definition and then the spacing between frames.  Solve just like any other arch or curved beam/column assembly.  Plywood strengths range from poor to extremely strong depending on wood type, inner layer void/check treatment, glue type and outer veneer types.  Cost per strength ratio is probably best with MDO panels but Marine Grade AB is one of the best for absolute strength characteristics.  Great amount of research has been done using plywood in marine yacht design.
24 Jun 08 13:05
Thanks civilperson.  I guess the main thing I have yet to find much info on is lateral buckling strength based on unbraced length, so that I can determine how closely I need to space my lateral bracing (purlins/girts).
Close Box
Join Eng-Tips® Today!
Join Us             Close
