Pull Out Strength Wood Screws
6
Hi All,
I am trying to find any data on pull out strength for wood screws fastening a aluminum flat plate to 6 or 10mm plywood.
Anybody any ideas?
Dave
RE: Pull Out Strength Wood Screws
As with any handbook value, use with caution as you do not necessarily know the assumptions, conditions and limitations that are associated with the data.
Something like this is likely to be highly application dependent.  If it's really important, your best bet is to conduct your own testing so you'll understand what was done.
APA - American Plywood Association
Maybe Forintek
Thomas J. Walz
Carbide Processors, Inc.
www.carbideprocessors.com
Good engineering starts with a Grainger Catalog.
5
Wow, now that's an answer.
Tom
Thomas J. Walz
