Panel Replacement
Panel Replacement
I have a GE Fanuc system with an outdoor operator's station. Installed in the station is a GE Fanuc Quickview Panel. Being outdoors the panel is occasionally subject to direct sunlight; long story short - they stop working when exposed to the sun.
I need a replacement panel that will hold up to occasional stints in the sun. I'm assuming that someone who manufactures a sunlight readable panel, has engineered a panel that will work when exposed to the sun.
So, I'm looking for a 12" sunlight readable panel, < 50 Watts, with an ethernet port. I've identified a number of qualified panels but I'm looking for somthing that has already been used with GE Fanuc so the drivers are available.
Any assistance would be appreciated.
RE: Panel Replacement
Why not correct the situation with a simple sun shade. This is how correctly installed electronics are normally protected in the field. Barring that, you need open vented enclosures and often lots of fans.
Keith Cress
We'll put up an awning and go with a non-black bezel, but my current reasoning is that if I have a panel that's rated sun light readable, the manufacturer has given some design thought to the sun striking it. If I buy a product line that has worked with GE Fanuc in the past I'll save integration costs.
GE has a panel called Wolverine that does everything except it weighs 35lb, is 15" and consumes 120 W; otherwise it's ideal.
Thanks for the reply.
However, I would not expect a "sunlight readable panel" to be functional while continuously exposed to direct sunlight.
I think your proposed solutions will work well.
Keith Cress
If you're thinking of changing panels anyway I suggest you check out Red Lion Controls, they have a panel with multiple protocol communications for about half the cost of some competitors.
I'm not sure they have a sunlight readable but well worth a look.
Roy
I've narrowed the search to marine panels, they seem to be the most rugged commonly available. I'm looking at the Vartech and Attro product lines. I was kind of hoping that one of the forum readers had experience with the GE Fanuc line and a sunlight readable display.
Thanks for the assistance.
