Unable to Activate Part Configuration in Assembly
I have a part with two configurations that I cannot get to activate in
the assembly. Both the default and the new configurations show in
part mode, but only the default part configuration shows in the
assembly tree. If I right click in the feature tree on the part to
access the properties only the default configuration shows in the
Reference Configuration dialog box. I also tried bring up the part
first and changing to the new config and then bringing up assembly to
load the part. Is there anything else I should try?
RE: Unable to Activate Part Configuration in Assembly
Timelord
