2D Pro/E (WF 3.0) save to dwg AutoCAD 2007 - scale mm to inches proble
We dump most 2D out of Wildfire 3.0 M090 into AutoCAD 2007 Mechanical. I have a Pro/E drawing in metric that when I save into AutoCAD, turns each mm into an inch. So I get a huge drawing in AutoCAD – a 2.5" diameter part becomes 65 inches instead of 65mm. I can scale it down in ACAD but then the dimensions in ACAD need reworked and there are 15 different styles to rework. I can explode everything and then scale it but don't want everything exploded. I tried scaling the model in Pro/E to inches, but this makes the Pro/E drw views a mess.
Is there a config setting in Pro/E that will scale this correctly for import into ACAD? Thanks.
Garry
Garry
RE: 2D Pro/E (WF 3.0) save to dwg AutoCAD 2007 - scale mm to inches proble
Hope this helps.
Farmboy
