Sealing for Valve
Sealing for Valve
in my products I'm using Coprax valves.
http ://coprax. com/prow.p hp?prow=00 0copr2show &id=1& amp;mode=0 &item= 18&cat =0&psq=
after 1-2 months seal is broken - material simply sucks.
Environment is: clear water, max 90C.
So my question is simple :) - what kind of rubber/silicone do you suggest? I need to order my own seals - that's the only solution.
Have you got similar problems in past?
http
RE: Sealing for Valve
