BS&W calculation
BS&W calculation
BS&W calculation
Hi all,
am developing a fairly complicated well clean up model and am trying to figure out how long it will take for the BS&W at topsides to be acceptable.
Now no one I have spoken to has been able to give me a direct answer of exactly how BS&W is calculated ... they generally say "Oh we take a sample, chuck it in a machine and it tells us" ... that doesnt really help me.
How is the BS&W calculared. Is it simple a volume ratio i.e. vol of Sediment and water vs. vol of HC fluids? or what?
Cheers
Read the Eng-Tips Site Policies at FAQ731-376: Eng-Tips.com Forum Policies
RE: BS&W calculation
I think there is an Esso patented method out there somewhere which might give an explanation (this is for flowing crude and uses density measurements).
This is a link to a dictionary that desctibes what it is and how it is measured:
http://books.google.co.uk/books?id=E49NJEssz3kC&pg=PA34&lpg=PA34&dq=Base+sediment+and+water+crude+oil&source=web&ots=PXx-112r7a&sig=_npM3f7QfY9tqLWh1EOLgdP2uSA&hl=en&sa=X&oi=book_result&resnum=1&;ct=result
But I'm not sure how that may help.
JMW
www.ViscoAnalyser.com
Thank you JMW! I think that first link has answered my question ...
"It is measured by volume on a centrifuged sample of the oil ..."
Therefore I guess that a BS&W of 5% in a 100ml sample would indicate that there is 5ml of water and sand and 95ml of hydrocarbon ...
We do that on a daily basis, about 100 times a day. All we use is a sample spinner/centrifuge. Yes, it is a simple volume ratio. In our case the concerns are the thickness of the interphase emulsion between the oil and water (receipts) and the straight BS&W for pipelining the oil (product)
<<A good friend will bail you out of jail, but a true friend
will be sitting beside you saying " Damn that was fun!" - Unknown>>
We sample on the 'waste' received (straight off the truck) and samples off the shipping tank prior to pipelining it.
