Peroxide Etching of titanium for bonding
We are currently experiencing some problems with bonding titanium 6Al-4V to epoxy resins- the geometry of the joint in question leaves a lack of access for our standard titanium preparation method; abrasion and then exposure to plasma. Therefore we would like to run some bonding trials after the titanium has been pretreated by etching using a Hydrogen Peroxide based solution as some of my colleagues have successfully used this method in the past. However they do not know the exact formulation of the etchant used nor the time and temperature of treatment.
Is there anyone who could provide me with this information - I have spent quite a bit of time on the web with no success!
Thank you in advance for your assistance.
RE: Peroxide Etching of titanium for bonding
Surface Preparation and Pretreatment of Structural Adhesives
-Ciba Adhesives
I have several formulas for removing TiN if you think those might help.
I would also try finishing.com for this.
tom
Thomas J. Walz
Carbide Processors, Inc.
www.carbideprocessors.com
Based on my experience with bonding Ti (Gr2) you will be remiss if you don't use a primer for you adhesive. We used an anodized surface for our work.
http://nt
http:/
http://www.sae.org/technical/standards/ARP1843A
