Delrin and static charge buildup
Will Delrin build up a (significant) static charge with air blowing over it?
RE: Delrin and static charge buildup
heather, Depends what you mean by significant... but yes, you can accumulate a charge with Delrin which can attract dust and fibers which then may cause defects depending on your process.  I would suggest buyiong ionizers to put on your air blows, worked for me and my processes.
