multiphase pumps
multiphase pumps
multiphase pumps
Hi everybody,
could you tell me where I can find some informations about multiphase pumps, their classification, use, limits, selection criteria... ?
Thank you in advance!
RE: multiphase pumps
You need to ask a much more detailed question.
Google it
<<A good friend will bail you out of jail, but a true friend
will be sitting beside you saying " Damn that was fun!" - Unknown>>
pump manufacturer catalogs or websites?
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
multiphase pumps, what phases, liquid solid, soild gas, gas liquid, or all three?
I need to know more about pumps that can be used in a petroleum well head. I have to compare different solutions for transporting hydrocarbons:
- separating the 2 phases (oil and gas) and transporting each single phase
- pumping the whole fluid that I obtain at the well head.
The phases are liquid-gas.
Do you know a book that permits to go deeper into this matter?
Thank you!
Well, this is a totally different matter than I was expecting. How are you planning to get the produstion out? A pump jack? Are you using a separator afterwards to separate the production gas or a tank? This would probably be the simplistic simples approach. A pump jack, depending on the conditions, would probably get you the production to a storage tank quite a ways.
