What is the difference between snow drift and snow sliding?
I thought they were always the same, but the Canadian Code distinguishes between both and requires a 50% increase in snow drift values to account for snow sliding. Can anyone clarify please?
RE: What is the difference between snow drift and snow sliding?
A snow drift is basically when you have an obstruction such as a higher roof that is flat. If this roof has a slope to it, and snow can slide off of this roof onto the lower roof, that is sliding snow.
Gotcha. Thanks.
Drifting occurs at obstructions such as a large air handling unit or screen wall, at parapet walls and at the wall between a high roof and a low roof.
Drifts can be formed from windward or leeward winds. The upper and lower roof surfaces can be sloped or level.
