two transformer using the same core
Hi all,
In our mill there's 2 transformer in the same tank for electrolysis thyristor rectifier (12 pulses) that uses the same 3 legged core.
Does anyone know any advantage/disadvantage about this design (apart from the cost-saving benefit)?
Any info/paper?
thanks!!
Any info/paper?
thanks!!
RE: two transformer using the same core
You understand this aspect correct?
Otherwise your question is not clear enough to me, perhaps others?
Keith Cress
My question is regarding the transformer's design, I mean, two different transformers, with their coils using the same core, one winding group (HV and LV) above the other, in the same leg, per phase. 3 leg core.
sory about my english!
thanks!!
Normally, on a twelve-pulse drive, this is a three-winding transformer with one secondary wound delta and the other wound wye.
Connection is Yd11-Dd0
Bill
"Why not the best?"
Jimmy Carter
