What is "Infinite Resistance"?
I am working with a specification that states "Infinite Resistance" between all non-ground pins of a connector and the ground plane. What can I use as the practical limit for measurement using standard equipment and practical as far as standard practices?
Circuit is 28V Nominal DC. (12-32VDC)
RE: What is "Infinite Resistance"?
I was wondering if there was a generally accepted definition of "Infinite"
For a connector -- unless it is some special appl.
e.g. charge amplifier input -- many megohms is
for all practical purpose infinite.
It would help is we knew if the connector is input or output and what kind of circuits.
<nbucska@pcperipherals.com>
The circuit is a timer/driver circuit for solenoids.
DC voltage 16-32 V. Max current 2 amp.
On the output side there is no problem: A few KOhm would
be good enough i.e wet cardboard would be acceptable
insulator.
I assume there is no some specially sensitive circuit
for you would have said so.
The timer must have some trigger input. The input may be
driven by a circuit or switch. A switch is very seldom
operated with very low current.
If the connector is disconnected, the circuit doesn't have
to work; the only problem is safety.
If the circuit is bipolar, a few MOhm is acceptable. Unprotected CMOS input is unlikelly since it would be too sensitive for static.
