WATER SUPPLY REQUIREMENTS
Hello all,
I have a project where the fire pump water supply is from a pond. Is this permitted? What code covers this area? NFPA 20? In addition, do I have to monitor the level of this pond, if I do should I do so with pressure on the inlet of the pump rather than a floatation device (like on a tank).
Thanks Again!
JT
Thanks Again!
JT
RE: WATER SUPPLY REQUIREMENTS
http://www.eng-tips.com/viewthread.cfm?qid=172038
