Importing Time-varying force signal in ANSYS workbench !
Hi everybody;
I just would like to know if anybody could help me by telling how I can import a varying-time force to apply it on my geometry imported to ANSYS workbench. The force siganl is 100 samples and written in a TAB-delimited .TXT file.
Thank you in advance,
Shaban
Shaban
RE: Importing Time-varying force signal in ANSYS workbench !
I suppose you can first get it into Excel, then COPY the cells (TIME in the left column, F in the right one). In Workbench, once you properly set up your analysis to include a number of steps corresponding to your input listing, in the "Tabular Data", simply PASTE your data in.
I never tried it directly, though; I'm only guessing.
I've tried your solution and it worked very well.
Thank you very much.
Chaabain
