STEP Translators
STEP Translators
Is it possible to export a saved Csys ?
Do any of the other translators support this ?
Specialty Engineered Automation (SEA)
http://www.sea4ug.com
a UGS Foundation Partner
RE: STEP Translators
This works for STEP203 and STEP214, as far as I can see IGES translator doesn't support coordinate systems. I also couldn't tell you at this stage what you'll get in other CAD systems.
Cheers
Hudson
Thank You, I do see the Coordinate Systems option in NX5. I was originally looking in NX3.
However, using 5.0.4.1, I simply get a <Internal error: memory access violation> when exporting a STEP file.
I'd say something hasn't installed properly because it worked the first time for me under the same version of NX-5. I used STEP203 because it was just the one file.
Best regards
Hudson
I ran NX5 out-of-the-box and it worked fine. I've obviously got some DLL's loading at startup that are causing the issue.
Thanks again,
