propane camshafts
propane camshafts
does anyone have any suggestions on a cam for my 496 chevy.
it's a 13 to one on full time propane hooked to a 2500 stall turbo 400 transmision, running 4;10 gears.
at this point i have a comp cam marine grind but the package is a bit slower than the previous 454.
i know a close match is an alcohol grind
the streetability is an issue as i do drive the car on the street as well as tow a small travel trailer on the highway
RE: propane camshafts
Towing a small trailer with your combo should not be the slightest problem so should not come into consideration for cam selection, unless your definition of small is a tonne or more and you already have something like 280+ duration at 0.050" lift.
You might want extra lift, but you give no indication of current cam specs, car weight, or port flow at various lifts.
What is streetable to one guy is a wild untameable beast to another, so decide on how it compares to your current cam and what difference in power curve you want.
If you have a flat tappet cam, you can get the best of both worlds by going to a roller, but at the significant cost of a steel cam, bronze dizzy drive gear, roller followers, suitable aftermarket rockers and pushrods and much stronger valve springs and retainers, and the machine work and labour to fit them.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
With LPG you lose slightly with VE so you need a little more airflow to maintain power.
My experience is limited to 2 engines.
