Matrix Bandwidth
Matrix Bandwidth
Hi guys,
Every FE textbook I open seems to begin with a quick word on stiffness matrix bandwidth. My question is, will a stiffness matrix with a particulary large bandwidth, be more likely to become ill-conditioned than a model organised such that the stiffness matrix has a particularly narrow bandwidth?
Or is narrow bandwidth only ideal because it requires less storage capacity?
I am using a solver that allows me to only store the non-zero entries in a matrix, so in terms of storage space, it becomes irrelevent on whether my stiffness matrix has a narrow or large bandwidth.
Before anyone asks, I am not a student posting a homework question, I am basically trying to programme my own frame analysis routine?
RE: Matrix Bandwidth
However, a sparse solver is MUCH more complicated and done incorrectly, may cost you quite a bit. For relatively small models, it doesn't really have any advantage anyway.
If you are writing your own code... I personally recommend that you write your own solver the first time through (rather than use a canned code ). It's the only way you'll truly understand all the differences in the decisions you make. For instance, how you accumulate the data on your model, the numbering etc. may be directly influenced by the solver code/method that you are using.
A bandwidth or a skyline/envelope solver (better than bandwidth solver) are usually a good way to go the first time through. They're certainly easier to understand.
Read up on Gauss and Cholesky methods for solvers. It's a good starting point.
Dan
