Ignitron equvalent & Induction furnace Converters
We have old Induction Furnace (Make KORF)of 2ton. It is having static frequency converter of 1300Kw with input of 700V & 50 Hz & output is variable voltage & maximum frequency of 500Hz. In frequency converter there is one pre current device which is having Ignitron (Mercury arch rectifier) to give starting energy to Capacitor & Inductor. Can anybody through the light on pre current device? How it works? Ignitron(English electric valve Co.,BK484/55524) is bad. Can anybody suggest for its equivalent device as they are no longer available in market?
RE: Ignitron equvalent & Induction furnace Converters
The precharge circuit either uses a transformer and rectifier (only if the precharge is used when starting the inverter) or a series resonant circuit with a thyristor in it (if the precharge is used every cycle).
Do you have ant drawings available? We may be able to help if we knew more about the circuit.
Gunnar Englund
www.gke.org
http://en.wikipedia.org/wiki/Mercury_arc_rectifier
