Scatter overlayed on Polar
I need some advice on how to execute the following graph.
Essentially I have a fixed point determined by location information (UTM East and UTM North, both in meters). I need to graph two concentric circles around that point at 50 and 65 meters around that point. I then need to overlay or insert a scatter chart several series of data points.
The point of all of this is to see how close vehicles come within a certain point using the 65m and 50m "rings" as points of interest.
I've attached something like what I am talking about. I created this in paint.
Thoughts comments?
RE: Scatter overlayed on Polar
The vehicles locations are in the same metric (UTM coordinates) as the fixed point. Just FYI is anyone wondered.
The only challenging part is getting 1:1 aspect ratio for circles.  Do you need that or are ovals acceptable?
There are a few old threads on that subject.
As suggested, use an xy graph for everything.  Generate the circles from a series of straights and format to display lines only.  Plot the other points as marker only.
Look here for a couple of alternatives for scaling the graph so circles plot as circles, not ellipses.
http://newtonexcelbach.wordpress.com/2008/06/01/drawing-in-excel-1/
Doug Jenkins
Interactive Design Services
www.interactiveds.com.au
