Node to Node Thermal Resistance
Is there an element type that will allow me to connect two nodes together with a fixed thermal resistance (such as 5 degrees celsius per Watt)? I would think this should be possible but I haven't been able to locate what kind of element to use in the documentation.
RE: Node to Node Thermal Resistance
